Can I get more than one output from a program
  • August 25, 2010
  • 30 replies
  • 16938 views
I am trying to get three output from the same preogram. is that posible?
Hinnd Naser wrote:
I am trying to get three output from the same program. is that posible?
Yes, just a matter of programinging for that end.
While that answer is undeniably correct, I don't think it's all that useful!
Quite correct in this "Théâtre des variétés" !
Yes, but only if the outputs all have the same units. Make the last line of the program a vector with the desired outputs.
h_nas1-VisitorAuthor
can use more than one input, and get an output for each one.
Thank you
Sure. If Pointless is a function definition just pass the function more than one argument. Or if Pointless is just a variable assignment rather than a function definition, it will pick up on any variables defined prior to the program in the worksheet.
