Can not explain error using lsolve function
- March 16, 2013
- 14 replies
- 3875 views
Help!
I am trying to solve a set of simultaneous equations (25 variables) and I am not getting the results I am expecting. I have compared my MathCAD solution to bothe actual results and a PSPICE simulation.
I have distilled my problem to a much simpler example which I have enclosed and I cannot determine why the results do not match.
I have respresented the circuit as a simbple resitsor divider then added a simple low pass filter. With a frequency of 0 Hz (s=0) or a DC operationg point, I have represented the capacitors as an open circuit (Rcap = 1 / C*s). Since there is no current through RR3 or RR4, I know the results should be the same but with only RR3 in the equations, the results work, but when I add RR4, the results do not match.
