Change how divided units are displayed
  • April 19, 2013
  • 9 replies
  • 4579 views
The unit of density is kilogram per cubic meter, which can be written as
kg/m^3
or
kg
__
m^3
MathCad uses the bottom method for display, is there any way to make it show how it is typed above? I ask because I prefer it like this asit looks neater.I saw no such options in the Worksheet Options.
Best answer by ValeryOchkov
I think we can use this solution:
is there any way to make it show how it is typed above?.
Not the easy way, but it's possible
One easy way
Tricky Valery!
NovaStark4-ParticipantAuthor
There is no way to input the superscripts? I tried to do it with the superscripts, but it didn't work out for me. Though this does solve the problem.
You may use the small "3" (AltGr-3) as in my first post.
The superscript was exactly the reason why I was impressed by Valery's trick with the third root.
