Change number
  • March 3, 2013
  • 2 replies
  • 1351 views
Hi. All
Please help.
I want chane number 8.048*10^3 to 8048.
I uese Mathcad 14,
Thanks.
Best answer by Werner_E
dongchi 420 schrieb:
Hi. All
Please help.
Double click on the number and Result Format will open (alternatively you may choose from menu Format/Result). Her you find many options to format your results. You may pick to set Exponential threshold higher or switch the format from General to Decimal.
If you want to change the default format of all results in your current worksheet, you have to click at an empty space and got to menu Format/Result and change to whatever seems appropriate to you.
P.S.: For future questions - its always better to inlcude a worksheet - increases chnces for a problem solution. You do by switching to extended editor (upper right corner).
Werner_E25-Diamond IAnswer
Hi. All
Please help.
Athur1-VisitorAuthor
Yes. Thanks Werner Exinger.
