Copying to Microsoft words
  • April 3, 2011
  • 16 replies
  • 10001 views
Dear all,
I have a problem with copying my calcs to word document. I need to copy them to words document in order to organize every thing for my project. the problem is that i have to copy each page from Mathcad manually to words, but they appear as pictures which in this case i have to remove the frame around each equation.
Can any one advise me how to copy them without having to edit them manually which obviously take long time to do.
Looking forward to hearing from you
Regards
Alan
Best answer by MikeArmstrong
Try paste special and select Metafile. There doesn't seem to be a box around the pasted regions.
Mike
23-Emerald V
April 3, 2011
Alan,
Are you using the 'Save As' - 'Rich Text Format' option? You can load that straight into MS Word or Open Office Writer.
Stuart
Further to Stuarts reccommendation see the attached template.
Mike
Mike
Hi mike,
What do u mean by meta file, would you please explain me abit in more detals? thanks
Copy the regions in Mathcad, select paste special in Word and choose Picture (Windows Metafile).
Mike
thanks to every one for your advices, i don't think there is a solution for this particular problem unless i follow yuor adices.
Regards
Alan
Can you confirm which solution worked?
Mike
