Jun 19, 2026 12:20 PM UTC
Created Mathcad Prime worksheet using AI by converting an Excel workbook into Mathcad Prime worksheet.
Good morning, Community,
Please I need your help, I have converted some Excel workbook into Mathcad Prime worksheet, my problem is that the AI created the file but I cannot open the file in Mathcad Prime 11. Please see attached files for your attention.
Thank you
23-Emerald V
Jun 19, 2026 1:54 PM UTC
To date there has not been a single report of a mathcad or prime worksheet created by any AI, that would successfully be opened by the application.
The .mcdx files contained in your .zip archives do not even nearly meet the specifications of a Prime 11 file. So it is no wonder that Prime 11 refuses to work with them.
I dare say that if in the future an AI successfully creates a mathcad sheet, it would be for any of the old versions (real) Mathcad 1 through 8 or 2000 or 2001. Or else a Mathcad 13, 14 or 15 file. Those are .MCD files and .xmcd files respectively, not Prime .mcdx files.
You'll have to translate your Excel sheet to mathcad/prime the 'hard way', that is, by hand.
terryhendicott
Jun 21, 2026 10:17 PM UTC
There have been some past posts that dealt with the AISC shape database the latest in the post being version 16 of the AISC Excel database..  It will take me sometime to find them.
Prime can read the database as a matrix meaning all the variables are available to perform calculations of the section properties etc.
Can you upload your Excel spreadsheet for shape member check and perhaps someone will take the time to by hand convert it to Prime.
Cheers
Terry
terryhendicott
Jun 21, 2026 10:35 PM UTC
Found one of the posts.
Cheers
Terry
terryhendicott
Jun 21, 2026 10:38 PM UTC
Here is the post that dealt with version 16 of AISC Section database.
Cheers
Terry
terryhendicott
Jun 21, 2026 11:03 PM UTC
Hi Luc et al,
Have just spent some time with AI Chat GPT uploading Mathcad Prime 10 files for Chat GPT to learn.
It has just created a simple working Prime 10 file from a text description.
Simple beginnings.
Cheers
Terry
