Creating a function with n-arguments?
  • January 5, 2012
  • 17 replies
  • 6649 views
I am working with Mathcad and want to create a function to calculate the parallel resistance of n resistors. Therefore I would need a function that would accept n arguments.
Currently I have separate functions defined for 2 elements, 3 elements, and 4 elements:
Is there any way to define a function that would evaluate this expression for n elements?
Best answer by RichardJ
Sorry, but it is not possible to create user defined functions that take a variable number of arguments (even though there are built-in functions that take a variable number of arguments). It's one of a long list of long-standing requests. The best (perhaps even only!) thing you can do is what Vladmir shows. That can be simplified a little too:
Hello!
Please attach your Mathcad worksheet.
I'd rather not upload the entire worksheet, so I've posted an image of the relevant formulas.
Functions for 2, 3, and 4 elements:
RichardJ19-TanzaniteAnswer
May be so:
Yes, including ORIGIN is a very good idea! Necessary, in fact, because I always use ORIGIN=0, and my version of the function would in fact not work correctly in any of my own worksheets
We can have in some built-in function of Mathcad 15 (find, min, max, stack etc) n-arguments.
One example max(1, 2, 3, 4, 5, 6...) = ...
The max n is 50 (n = 1-50)
Do you know how much max arguments can we have in same functions in Mathcad Prime? I know more than 50 or 256.
Do you have a full list of this functions with var n of arguments?
