Differential Equation: Laplace question
What to do in the case of blue rectangle if someone wants to solve this differential equation using laplace?
Cornel19-TanzaniteAuthor
Second question:
Third question:
Forth question:
23-Emerald V
I see you are using Prime 9. One of the new features of Prime 9 is that it is capable of solving ODE's symbolically.
I suggest you try that, instead of going the Laplace route. If Prime is capable enough, it should be able to give the solution to your ODE as
Where c is a constant.
Proof:
Prime 9 result:
I want to have also the result with laplace transform (if it is possible)...as a second check
or when:
23-Emerald V
I find the result interesting.
What number could _z be if it is not part of the set of complex numbers?
