differentiate contour plot overlay
  • December 21, 2012
  • 7 replies
  • 2955 views
I do want to overlay two efficiency maps. I is possible to have different lines for the contours - one solid - one dashed?
Now I'm using Mathcad 15 but may be that is possible with Prime?
many thanks
Best answer by StuartBruff
Doh! "Special" tab, Line Style on the right hand side - solid, dash, dotted, dash-dotted.
Stuart
23-Emerald V
December 21, 2012
many thanks
I don't see an option to select the line type, but you can change line thickness and colour; you can even choose to have one displayed as a solid colour and the other as a colormap (eg, greyscale).
It may be possible to get a dash-like effect by defining your own colormap that alternates between, say, white and black or between light gray and black.
Stuart
23-Emerald V
December 21, 2012
Stuart
Efried1-VisitorAuthor
perfect answer - thanks a lot - also the artwork is great.
Now I'm hopping to the next problem - is there a possibility to have a colour scale legend added, so we can see for what numbers the colours of the lines in "colour scheme mode" stand?
thanks
Mathcad 15 or mathcad Prime?
I can do it thru plotting an add plot f(x ,y)=const
