Difficulty in defining when the first deflection takes place in a plot
Years ago Werner helped me in setting up a technique to define the first deflection in a curve. Now I have to make a similar analysis but unfortunately the worksheet miscalculates the first deflection in 5 out of 6 plots. I was wondering whether this could be optimized? I have tried a few approaches e.g. using a higher derivative but this only marginally improved my results. I have put the correct indexes in the worksheet as correct 1 etc. Any help or suggestion to improve the method would be extremely appreciated as I have to analyse 150 plots and would like to avoid doing this manually.
Thank you in advance!
23-Emerald V
How did you (independently from Werner's routine) determine the maxBend points?
With respect to set.1 you say the maxBend occurs at x=4.89 (rather than at 7.99).
Are you looking for maximum of the slope (1st derivative, I find it at about x=4.4) or maximum of the bend (2nd derivative, I find it at about x=3.3)?
FDS13-AquamarineAuthor
Dear Luc, thank you for your reply. As you probably noted the first part of the curve is of no interest (all impedance values below 20. What I am looking for is when the upgoing curve starts to deviate towards the right. Your proposed 4.9 value is correct. I obtained the "correct" values by visual judgement as I did not succeeded in finding a better method.
23-Emerald V
Filip,
My proposed value is not 4.9, that's your result. I get 4.4 for the maximum of the first derivative, 3.3 for the maximum of the 2nd derivative.
