Division Keyboard Shortcut Not Working
  • November 11, 2013
  • 10 replies
  • 3526 views
Everytime I press the / key on my keyboard (which should be the hotkey for the division operator), Mathcad outputs " é " instead. How do I get it to do what it originally does again?
Thank You
Which keyboard layout are you using?
Which "/" are you pressing - numeric keypad or "normal" part of the keyboard?
Is it a Mathcad specific problem? Does the "/" key work as expected in a word processor or in notepad?
VP_801011-VisitorAuthor
I'm just using the standard US keyobard layour. I'm pressing the normal key with / and ? on it. And yes, it shows up as a / everywhere else I type, just on Matchad it shows up as é for whatever reason.
Which version are you using? That will help narrow the search efforts.
For example:
In MC15 a ? used in a math region is the derivative shortcut, while in P3 the stroke returns just a ?. You have to use Cntrl Shift D in P3.
