DJM
  • March 16, 2011
  • 8 replies
  • 5827 views
After calculating a long series of values in MathCAD, it would be convient to summarize the results in a table as shown below:
Axial Max Shear Max
Case I
Case II
etc.
How do you generate a summary table of the calculated values? The finished product should look like a table generated in Excel.
Best answer by MikeArmstrong
Have a look at the attached simple example.
Let me know if your having trouble with it.
Mike
This can be done in Mathcad, but the tables don't look ascetically pleasing.
I tend to embed an Excel component into my Mathcad sheet and pass the variables to it.
Mike
DJM1-VisitorAuthor
Thanks for your reply. How do you display only the results of a series of calculations into the Excel spreadsheet (table?) ? I've only been using MathCAD for able a week.
Example:
Calculated Pressures
P1 = 2.5
P2 = 9.0
P3 = 7.2
Record # Pressure
P1 2.5
P2 9.0
P3 7.2
Thanks Again
DJM
Mike
23-Emerald V
March 16, 2011
Axial Max Shear Max
Case I
Case II
etc.
Do you mean something like the attached, Dennis?
Mike's right though, that it looks a lot better in Excel ... can't remember what Prime will allow.
Stuart
DJM1-VisitorAuthor
WOW! Thanks for your reply. I have only been using MathCAD for about a week and your WAY beyond me. The resulting matrix would consolidate the results in an orderly manner but I was hoping for a simplier solution.
Thanks Again,
DJM
Stuart's examples are usually superb and always worth keeping hold of.
Have a look at the attached a very simple example which might help get you started.
Mike
