Eathquake Load
  • February 2, 2010
  • 4 replies
  • 4334 views
Hello MathCAD Community,
Attached is copy of file I'm working on based on the Canadian Code on earthquake load. The worksheet is set-up to compute the spectral acceleration values for a particular site. My goal is to automate the worksheet to handle any site condition.
The main objective is to calculate the S(T) which is the design spectral acceleration values using linear interpolation for intermediate values of T. Please see the highlighted paragraphs in the worksheet. Would anyone be kind to help.
Regards
Moses
>Regards
>Moses
___________________________
Your work sheet may interest a larger audience than the version attached, restricted to probably 14 users. If you wish to share, even get more collaboration (sometimes faster), please "Saves as" 11 or even lower.
jmG
PS: some earthquake have been recorded in Canada, bad ones too, even in Qu�bec.
February 3, 2010
For some reason I can't download Val's file so can't see what his solution is. In case you have the same problem, here is a possible solution.
stv
