Eigen value resbustitution error
- April 8, 2013
- 2 replies
- 1106 views
There appears to be some bug in Mathcad 15. In the attached file I used the function getvals for the eigen value problem. I get the same answer by calculating the determinant of the matrix. However when I substitute the eigen values in the main equation, it leads to a very big number. It should give me zero or close to zero. However, when I solve the problem with fraction numbers as results it gives me the exact answer.
The problem is that the solution given in the first case should lead to a small number close to zero not a huge number with 10power 9. see attahed sheet.
