Embedded xls appear as black rectangle in pdf?
  • June 1, 2012
  • 8 replies
  • 5134 views
To all,
When printing a mathCAD document to PDF (using PDF creator) all embededd excel spreadshees are not printed properly. All I get is a black rectangle where the xls is. Any suggestion(s) or work around?
Update
For some reason one always find something (possibly) relevant after posting the question !! Found a thread giving the following 2 links but cannot access them
http://collab.mathsoft.com/read?115413,11e#115413
http://collab.mathsoft.com/read?112852,99e#112852
Any suggestion on how to access them?
Regards
JXB
Those links are permanently dead.
Use a different printer driver. Cutepdf is free and has solved problems like this in the past.
Can you attach your Mathcad worksheet to the message?
I don't see any problem by using Acrobat PDF Reader 10.1.3 and Mathcad 15 M010. What version of Mathcad are you using?
