Valery,
I don't think the assignment statement (with the arrow) allows a program to be assigned, only a mathematical expression.
The following would work,
There is no need to define a "subroutine" or program construct within another. They can be defined individually and then used within each other as I have shown above.
Harvey Hensley wrote:
Valery,
Thanks, I know it,
but I want to have a program built from separate debugged modules without user functions!?
Not so much an error as a convention. The "return" operator stops the whole program, not just the module. Remove the first "return" in your examples and the results are as expected.
Alan
Very strange behavior.
Mike
Mike
In Mathcad MM and Mathcad Prime Minister all is OK - see http://communities.ptc.com/docs/DOC-2513
