Error using Minimize inside a user defined function
- January 9, 2012
- 10 replies
- 4903 views
Dear All,
I'm trying to use the Minimize function inside a used defined function and I'm getting the following error "The variable is undefined" but outside the function it works very well.
As you can see the function was get from the Examples from the mathcad help my problem is similar to the one on the attached file.
Thanks in advance,
Lourival
