Error with For Loop Return Value
  • March 27, 2014
  • 6 replies
  • 2005 views
I apologize in advance if this is an easy quick, but I am new to Mathcad. I found the attached For Loop example online and would like to modify it to use, however I am receiving the following error "Variable is undefined." I copied the example verbatim and from what I could find online, the syntax looks correct. Can anyone provide comments on why I am receiving this error?
Thanks.
Best answer by MikeArmstrong
Firstly never apologise for asking questions.
Have a look if the attached helps. You use text subscript instead of a vector subscript (keystroke [ ) operator.
Never? Even if, for example, you asked your wife why it was such a big deal that you forgot your 10th wedding anniversary?
Brilliant.
I think would have to come under the 'rhetorical question' category though.
