Expressing result in defined unit
  • February 1, 2012
  • 12 replies
  • 5299 views
Hello, I am a new user to MathCAD, and after searching other posts a bit I am still at a loss of how to express my results in a unit that is not available by inserting a custom unit. What I would like is to have my results expressed as "Msi". I can define the unit of Msi as 1*10^6 psi, but my results -- albeit correct -- are still displayed in psi. for example, if I defined M:= 42 Msi, the answer is expressed as M=42*10^6 psi. What I would like it to display the result as is "M=42 Msi". Is there a way to do this? Thanks for any help.
Best answer by RichardJ
Click on the result, and you will see a placeholder to the right. Type the desired units into the placeholder.
Mathcad 15:
Same in Mathcad Prime 1.0 but without an area.
Areas we will have only in Mathcad Prime 2.0 - as we say in Russia "Хорошего понемножку!" Or "Обещанного три года ждут!"
I do not know correct translations of this Russian sayings. Can you help me?
As Valery has indicated, you can create user defined units. Usually these are kept in a hidden area at the top of the worksheet.
Mike
When I need new units I do a reference on one sheet on Mathcad Server - and no problem.
When I see a new unit (Msi for example) I add it in this file:
Good shout Valery, the only issue with that is that the worksheet is dependant on the reference worksheet then.
Mike
RichardJ19-TanzaniteAnswer
http://communities.ptc.com/servlet/JiveServlet/downloadImage/2-175199-28271/183-189/Msi.png
