EXTERNAL: Units
Funny you should use tire sizes. While the wheel size is in fact in
inches, the section width is in millimeters. Since the side wall height
is a percentage of the section width, determining a tire's height is
difficult as you have to convert units to do the math. Knowing how tall
a tire is is important if you're changing wheel sizes and you want your
speedometer accurate.
Doug Schaefer
Doug Schaefer
