Externally defined symbol and '#ifndef '
  • August 9, 2012
  • 12 replies
  • 8467 views
Hi all,
I am using OLE automation to excite my maths model with input data taken from a spreadsheet so using .SetValue, .Recalculate and .GetValue methods of the Worksheet class. For that reason I have added the name of the input variables right at the top pf the file without the := operator.
My problem is that I want my MathCad model to be also a standalone model where it will look if automation is active or not, and when not, it will have a local definition with :=
To do that in C, we would define a global symbol when in automation:
#define OLE_AUTOMATION
And then in the program we would add a conditional compilation branch
#ifndef OLE_AUTOMATION
int variable_input_x;
variable_input_x = y;
#endif
Is there any way of doing something similar in Mathcad?
Many thanks
Best answer by RichardJ
Sort of. There is a way (although it is a kludge!) to trap an undefined variable: see the attached worksheet. That means you you can set up the worksheet to use the input variable if it's defined via the OLE interface, or a default value it it's not.
RichardJ19-TanzaniteAnswer
That's great Richard, thank's a lot
