FEM calculations on mathcad
  • March 1, 2006
  • 5 replies
  • 5636 views
I'm struggling to calculate moment frame construction using finite element method. Could somebody help me with a useful link to a similar mathcad worksheet?
Sincerely,
Victor
Search this forum for "finite element"
Also visit here:
http://www.gundermann.dk/mathcad/finelem.htm
There is also an electronic book, "finite element beginnings" that is part of the Mechanical Engineering Library from Mathsoft:
http://webstore.mathsoft.com/dr/v2/ec_Main.Entry17C?SID=7855&SP=10023&CID=0&PID=760511&PN=1&V1=760511&V2=&V3=&V4=&V5=30012754&CUR=840&DSP=&PGRP=0&ABCODE=&CACHE_ID=0
Richard
November 13, 2006
Victor
Have a look at the beam structural analysis worksheet contained in the DynamAssist Handbook. This can be downloaded from the Mathcad website and I think this may do what you want.
Regards
Ian Ward
November 17, 2006
Relevant sheet attached.
Regards
Ian Ward
November 22, 2006
Hi Ian,
Can you please tell me what the variables gamma,alpha, Damping C and Delta T are in your Beam example. I pressume "A" and "J" are the area and torsional constant.
Tonymac
November 29, 2006
Hi Tony
I should have put a bit more explanatory text in the worksheet. You are right about A and J.
If you take a look in the 'Static analysis calculations' area in the worksheet there is a bit more explanation.
The other values you asked about are:
gamma = rotation of element about its own axis(there is a diagram showing this in the User Manual area).
alpha = thermal expansion coefficient
delta T = temperature difference
C = damping coefficient
regards
Ian
