file storage
  • April 28, 2010
  • 2 replies
  • 2586 views
What is the quickest way to:
1. convert a MATHCAD array into EXCEL .xls array
2, convert a MATHCAD prn file into an EXCEL .xls array file
Use a File Output component
Read it in and write it back out again using a File Output component.
Richard
We can copy an array in Mathcad and paste it into Excel and back!
Same
>Thanks
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
>Same
>>Thanks
>Val
___________________________
Yes, the quickest way is often the direct way.
"what the time does not build, the time destroys"
"Ce que le temps ne fait pas, le temps le d�truit"
Jean
