Find-Replace error in Mathcad Prime 2.0
  • June 21, 2012
  • 2 replies
  • 912 views
I have variable a1, a2... in the sheet and want to replace on variable b1, b2... by the help the find a replace on b command.
I have after this command... b, b... not b1, b2...
And second
We can not find a replace variables in areas!
In Mathcad 15 all is OK!
In Mathcad Primw 3.0 all must be OK!
Valery,
I'm able to find and replace variables in areas in Mathcad Prime 2.0.
Mona
There are also issues trying to replace certain variables or words that I've encountered, where the first portion of the variable (or a word) remains and the replacement is added on to it. for example, if I try to replace the variable "VAR" with "const", then in some cases MathCAD will end up with "Vconst".
