Finding Centroids
  • October 19, 2010
  • 36 replies
  • 20120 views
Using Mathcad to find the centroid location of general shapes.
How'd he do? Would you take a different approach in finding centroids?
Best answer by f.kohlhepp
Your IT dept may have blocked you from accessing the YouTube site.
They have.
But centroids 'R Us:
Tough to say.
Video??
Do you want a worksheet as an example?
Mike
BTW - will the example worksheet be available to download?
Up to you Mike on whether you want to post a worksheet example. I haven't seen anything on the forums about centroids
You'll have to ask the author. This video I pulled from YouTube.
A slightly different approach as the attached sheet calculates a composite centroid in order to calculate the bending stress generated in the jack, might be worth a glance though.
Mike
The approach looks good to me. I am a little disappointed, however, that units were not used in the example. It's good that he's solving by integration rather than just teaching to look up equations from a book, but the numbers have no meaning without units.
Dan,
Its a good example but not very practical. He doesn't explain how he gets the curve function f(x) and for the second example he just makes a curve up. Unless I'm wrong this method can only be used if the curve function is given.
Mike
Follow Fred's example, and use interpolation to generate the function. Using the closed spline from Tom's spline routines may be a better choice than linterp in some cases though.
Cheers.
Mike
