Finding maximum value is failing
  • October 23, 2010
  • 4 replies
  • 2836 views
I'm trying to find the maximum value of a curve. simple stuff.
but it fails and gives totally wrong answers.
File is attached M14
Best answer by RichardJ
The answer it's giving you is correct, it's just not the answer you want.
RichardJ19-TanzaniteAnswer
Thank you
btw which of these is the fastest Quasi-Newton, Conjugate gradient or Maximize function
Maximize uses either Conjugate Gradient or Quasi-Newton as the algorithm. There is no way to know a-priori which will be faster.
