finding the maximum
  • August 9, 2013
  • 2 replies
  • 1658 views
Could some one point out where im going wrong in finding the maximum of my function. I thought it should be trivial.
I want to create a generic way to pass any function. Please see attached.
Jason
Jbryant611-VisitorAuthor
Its OK, I've done it. I changed the order of the two line sin the for loop and it worked 😉
Jason
Or maybe better using just one if-statement
or even a more analytical approach (with all limitations of root, of course) which will yield more precise results more quickly
Or
Here is a version with some error handling which should work even if the extremum is not between xlo and xhi.
