fit mutual fund data
  • September 22, 2013
  • 4550 views
I have been trying for hours to setup a solve block for what I thought would be a simple task with no results. I would like to enter data representing mutual funds and find weighting coefficients to find the best fit to a given set of data. For example Morningstar summarizes stock mutual funds with a 3x3 matrix that gives the percentage allocation between value, blend, growth and small, medium, large companies. I want to calculate weighting coefficients for each matrix to force a prospective portfolio of funds to be a best fit to a given matrix representing ideal value, blend, growth and small, medium, large.
Just post the worksheet here to show what you are trying to do.
I think I figured it out finally. The instructions said to use cntl = within the solve block but it started working when I changed to :=
That depends. You would have to use := for assigning guess values to the solved for variables, but you have to use the fat boolean = (ctrl 😃 for the constraints in your solve block.
But as it started working for you, you obviously had done it the right way.
