Fitting data
  • October 21, 2012
  • 5 replies
  • 4282 views
Hi. I need help for fitting data. I am looking a function which can fit a kind of tailed function. see attached the data that I want to fit.
May be the attach help you!
May be so.
Viktor
What's the purpose behind fitting the data? Do you just want interpolated values? Do you want to understand something about the physics, chemistry, whatever, regarding this data?
ok I will explain.
when we are going to the left to the right, I want to have the area of second peak which is the signature of one chemical compound. I have many voltammogrammes were this peak increase with the concentration of the analyte. so I want to fit the data with a kind of two gaussian function. when I use a sum of two error functions the fitting is not good.
I hope that now you understand my problem
ok I will explain.
I hope that now you understand my problem.
also, the function should have an electrochemical meaning. thank you
That's why I asked. I'm not an electrochimist thoiugh, so you will have to provide us with a function that describes what is happening. Given the expected form of the function, we can show you how to fit it.
we want to used two gaussian functions.
