"Folding" of text containing Math regions
  • April 25, 2012
  • 5 replies
  • 3537 views
I have voiced this before but thought I would again for Prime 3. I use insert Math region alot. However if I save a file with text and math regions within the text, when I reopen the file much of the time the text folds at the math region, that is everything from the Math region on is put on the next line. This usually interferes subsequent formatting. I then have to reformat the enire file, particularly if this happens multiple times in a file.
Best answer by MikeArmstrong
So you want to be able to insert Math regions into text again?
Mike
Mike
Joeboy1-VisitorAuthor
yes I do
Dixie
I agree 100%. Why PTC deprecated this functionality is beyond me. It causes so many translation problems when converting from MC 15 to Prime. Also in my view, the alignment of regions is dumbed down in Prime. PTC seem to believe that the grid is the panacea which it is not.
