Best answer by Werner_E
That way you changed your vector X.
I had something like this in mind
You need two more equations. Otherwise you may chose two variables freely and can calculate the third.
The questions doesn't seem to make much sense.
lvl10720-TurquoiseAuthor
20-Turquoise
August 16, 2013
Many, many thanks, Werner.
Best Regards.
May be so:
20-Turquoise
August 17, 2013
Hello, again.
Thanks in advance for your time and help.
Best Regards.
You should remember from former questions of yours that Mathcad's Find won't work with indexed variables!
Can you further explain what you are trying to do at the end? What are all this calculations for?
20-Turquoise
August 17, 2013
