Global Definition
  • January 6, 2010
  • 24 replies
  • 10123 views
All the best everyone.
I have a question regarding the disadvantages of the Global definition. I know that it can�t be used when extracting data from Excel component, but cannot find any additional disadvantages.
The one major advantage is that results can be displayed above the calculated area, which is very useful when producing formal documents.
Regards
Mike
January 6, 2010
I never use GLOBAL because most often I re-use equations or re-define variables in a worksheet. If you are doing one calculation in a sheet then using GLOBAL may not be an issue.
Preston
Ok cheers.
The main issue is displaying results above where they have been calculated without manually changing them when an input is changed.
Regards
Mike
On 1/6/2010 11:46:14 AM, Armo wrote:
>Ok cheers.
>input is changed.
>Regards
>Mike
Huh? You listed that as an advantage, so what is the issue?
TTFN,
Eden
23-Emerald I
January 6, 2010
And your question is?
Fred Kohlhepp
fkohlhepp@sikorsky.com
Basically, the restrictions within Mathcad when using this definition.
Regards
Mike
