Graphs - Problems
- December 27, 2013
- 0 replies
- 4074 views
Making graphs takes practice, so there are three problems in this section. Remember, you can always adjust the range variable after you have defined some rough values. In some problems, you will be able to define your range in terms of the information given in the question.
After you have worked out the bugs in your graphs, make sure they have a title and descriptions of the quantities (and units) on each axis.
