Help calculating range of output, with component tolerances
- April 17, 2013
- 5 replies
- 4443 views
Hi.
I am new to using MathCad, so I hope I am not asking too simple of a question.
I have to calculate a voltage range on my input pin, depending on component tolerances and voltage tolerance. lets say I have a voltage which ranges from 6 to 18V,nominally at 12 and a simple voltage divider with R1/R2, each with 5% resistors, which functionality of Mathcad would give me a nice output of voltage ranges on my output ( that is between R1/R2).
the circuit is naturally more complex, I am just trying to lean how to and then expand once I know.
with this simple circuit, I would just put in min and max values and only have a couple of individual calculations, but my actual circuit has a lot more components, and calculating the range of outputs, with tolerances becomes a large task, if there is no function to give me the range
I btw, am using MathCad Prime 1.0
thanks very much in advance.
Kasper
