Help: error with integration - need setup assistance
- January 18, 2012
- 6 replies
- 4379 views
I'm trying to reproduce a result over a range of values for specific volume. I was able to run through the equation and I got a result as expected on page 1 with a defined specific volume.
I then tried to reproduce and graph the results if I varried the specific volume over a given range (page 2), but ran into a issue. I know the integral is producing the error, but don't know how to properly set up the integral in MathCad over a range. Any help on setting up the problem differently or how to work around this issue would be appreciate.
Tyler
