3-Newcomer
April 20, 2011
Help for a VBA-->Mathcad program
  • April 20, 2011
  • 10 replies
  • 6724 views
Hello! I need to transform a short program from Visual basic to Mathcad. The algorithm is for determination whether point lies inside or outside of polygon. I have written program in Mathcad, but according to the result - incorrectly. Please help.
thanks in advance
Rosen
Best answer by StuartBruff
thanks in advance
Rosen
I haven't checked your program in detail, Rosen, but it seems to work when given a (closed) square to deal with.
I've given an alternative implementation using 'continue' rather than nested if statements. This allows an implementation that is closer to the original. I've also a set of test points that track through the polygon.
Stuart
23-Emerald V
April 20, 2011
thanks in advance
Rosen
Stuart
23-Emerald V
April 20, 2011
... forgot to add.
I removed the image of the VBA code to reduce the file size.
I haven't checked it as don't have time ... so, caveat emptor!!
3-Newcomer
April 21, 2011
Stuart, thanks again! Except you are Mathcad expert, i saw you achievments in Russian (at russian Mathcad forum),Bulgarian, and Latin languages and I am impressed:)
I think your program will be helpfull for other users, because i didn't find in Internet any algorithm for point in polygon, programmed in Mathcad.
Пожелавам ви приятен празник!
