Help needed on Tables !
- May 6, 2013
- 1 reply
- 1851 views
I have a table, where one cell has equation which is the addition of Two cell, if I drag the output cell, all the rest of the addition will be applied to those cell.
Where I can only change the input, which save my lot of time.
I have attached the reference file and mentioned the example below.
"After inserting the formula in cell F8, which adds the values of A & B.To Apply the same formula I can drag the F8 cell and all the formulas can be applied to rest of the column."
Amit
