Help Newbie and Complex Numbers
  • April 11, 2010
  • 2 replies
  • 1460 views
Hi All
I'm trying to write an equation where the co-efficient of the complex number 'i' is a variable. Tried
(G2 + C1.i)
But no joy - equally as bad is:
(G2 - (C1 + C2)i)
I don't want to keep changing the various coefficients manually and can't see any reason why it should be impossible for Mathcad to handle the general requirement.
Any suggestions? Can you put me right? I have tried reading the manual and Googling the situation but all examples 'convieniently' use numbers as the coefficient!
Cheers
James
On 4/11/2010 10:25:37 AM, stuartgregory wrote:
>Hi All
>equation where the
>Tried
>(G2 + C1.i)
>is:
>(G2 - (C1 + C2)i)
>handle the general
>requirement.
>the coefficient!
>Cheers
>James
Simply try
G2 + C1*1i
or
G2 - (C1 + C2)*1i
The "1" in front of the "i" tells Mathcad that its a number, not a variable. Wehn the regeions does not have the focus, the 1 its hidden for better display.
RMIx
Hi rmix22
Thanks for replying - I know it is the right answer for me as I found it myself a few minutes after asking the question but after about 15 hours of puzzling and researching beforehand!
It isn't too obvious from the Help files but is if you read it again knowing what the answer is! This is often a big problem where people writing 'HELP' are experts in the subject.
Forums - love 'em!
James
