Help turning textbox inputs into matrix
  • July 12, 2013
  • 35 replies
  • 12059 views
I am trying to create a matrix of numbers from a textbox and having a little trouble doing it. I would appreciate any help I can get. I have attached a sheet with my problem.
Thank you!
Best answer by Werner_E
I wonder why you would go through all the hassle of using a scripted component and converting its output to a vector instead of inserting the vector directly or via table input. Its more complicated and far more failure prone in my opinion.
Best approach possibly would be to let the VBasic script do the parsing and return of a vector.
Nevertheless find attached yet another solution using Mathcads programming facilities.
BTW, its not adviseable to mark the question as "assumed answered" from the very beginning as people might overlook it that way.
See the attach please
Valery beat me to it, but here's an alternative version.
Alan
Werner_E25-Diamond IAnswer
Yes. This requires very little code in VBscript.
There is a problem with localized Windows versions like the German one I am
working with - the decimal point is ignored here (our versions use the comma
instead of the decimal point.
I cannot insert a pic at the moment (don't know why it doesn't work) but I get "54" instead of "5.4".
