HELP WITH A GRAPH
  • May 26, 2011
  • 10 replies
  • 4779 views
Please help me to plot the graph in the attached MathCad file.
Thanks for the time and help.
Anousheh
Best answer by RichardJ
As Valery says, if you want to plot Y against X then either Y must be a function of X, in which case X must appear on the rhs of the function definition, or both X and Y must be functions of another variable that appears on the rhs of both function definitions (a parametric plot). I can plot
Y(X):=sin(X)
or
Y(A):=sin(A)
X(A):=cos(A)
but I cannot plot
Y(X):=sin(A)
I set yours up as a simple x-y plot, but it could also be done as a parametric plot.
If we have z(x, y):=... we must have x and y in right part of this operator of user function creating.
If we want to plot z(x. y) function we must at first check what returns this function:
x:=...
y:=...
f(x, y)=???
Anousheh1-VisitorAuthor
Thank you.
The left hand side of the function (equation) is simply: t/tau2. That is why I put it as T(t,tau2)
I need L/L0 on the y-axis and t/tau2 on the x-axis.
Thanks again.
Do you try to plot a parametric X-Y plot?
See http://twtmas.mpei.ac.ru/mas/Worksheets/curve2d.mcd
