18-Opal
HELP WITH GIVEN and FIND
- 5 replies
- 10356 views
- Translate All
I am trying to solve a set of equations using Given and Find. I wish to define some boundary conditions. Eg. I may wish to limit some answers to a range between 0 and 1 or limit some values to positive numbers numbers. I don't know how. Your help will be appreciated. File is attached.
Basically I am using current and voltage data from relays at both ends of a line to find a fault location.
If we limit all values to real and M is between 0 and 1
The expected answer for U is about 0.75 - 0.76.
