Help with Programming Maximum Function
  • February 2, 2011
  • 2 replies
  • 3493 views
I have a vector that represents monthly values for 30 years of data (i.e. 360 discrete values). I need to write a programming loop that finds the maximum value in each year. I'm having an issue setting up a counter on the "max" function. Any suggestions?
Please post a worksheet with the data and what you have so far.
amaurer1-VisitorAuthor
A draft worksheet is attached.
It's easier to do it by splitting out each year using the submatrix function.
That worked perfectly. I have never used the submatrix command, but I will now. Thanks for your help!
