Help with setting up an Equation
- November 15, 2010
- 6 replies
- 5359 views
I am fairly new with mathcad and I just have a quick question about setting up an equation.
I want to have the equation show the required variables and then show the actual values of the variables.
See Attached photo.
Now I write out the variables then disable the equation and then re-write again with the numbers in. Is there a way to do this with out having to re type. Thank you for your time.
