Help with solve blocks
  • September 24, 2012
  • 5 replies
  • 2213 views
I wasn't sure if I should post this in the calculus or algebra section as it pertains to both... I have a solve block set up that set's the function, the derivative wrt a variable, and then two other combinations equal to 0. I have 4 variables I am solving for. However, my solve block doesn't seem to work. Oddly enough, if I simplify the functions with my boundary conditions, and then just copy and paste into a new solve block, setting them equal to zero, it works. I don't understand what it is I'm doing wrong. Any help would be greatly appreciated. I've attached a copy of the sheet I'm working on.
Best answer by AlanStevens
See attached for how to make it work. It still takes some time to solve; mainly, I guess, because the derivatives are reevaluated every step of the way!
Alan
Valery,
Thanks for the quick response. There is, however, a solution to this system of equations (as can be seen by scrolling down in the sheet). I tried replacing the guess values with numbers close to the actual answer to no avail. Any suggestions?
Alan
