Help with Units
  • May 31, 2012
  • 11 replies
  • 7446 views
I am trying to do a fluids type equation problem in Mathcad 15 and I want units in inches per water, however it does not have those units therefore I have no clue what to do? Please help
Thank you
Best answer by Fred_Kohlhepp
Your equation needs density units (dynamic pressure) to get the units correct. I've shown you a fix, but you need to understand your equation better.
23-Emerald I
May 31, 2012
To use any custome unit, you only need to define it:
Here is my problem that I do not know how to fix. I tried your way
Where did the "4030" come from? This is an empirical formula?
I think it is an empirical formula.
(Or a pseudoempirical one)
Kevin!
Show please the origin of this formula!
Kevin:
See the attached Mathcad file.
Should answer your question about units for the 4006 number (or 4030 depending on constants used).
