Highlight Region
hi.
when i go to highlight a region the default color is yellow. is there a way to change this default?
thanks.
hi.
thanks.
if i right click on a region and select properties then click 'highlight region' then click OK - it still turns yellow!
It doesn't do that for me. When I change the default colour in the format menu, all I have to do is check the highlight region box and I get the chosen colour.
What version of Mathcad are you running?
There is another workaround if you want all the regions highlighted the same colour. You could just copy and paste the region which has the correct colour and change the variables within the region.
Mike
No account yet? Create an account
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
