Ho to remove vertical page lines in mathcad so closely spaced (ref attached mathcad sheet)
  • November 14, 2013
  • 2 replies
  • 2626 views
Hi ,
Can any one make the attached mathcad sheet normal. There are closely spaced vertical page lines . while printing small part of the shheets are only prining..
Thank you in advance for the help.
Best regards
Janardhan
Best answer by Werner_E
??? Not sure what you mean.
The vertical lines indicate the page size.
You set up the page size, orientation and borders via "File" "Page Setup" from the menu.
Werner_E25-Diamond IAnswer
Thank you.
Actually there was problem in system.
have ncie day
