How do i add a point in a chart
  • September 5, 2010
  • 20 replies
  • 16910 views
I want to add a specific point F(1) on a rectangular plot. but doing that gives me a horizontal line. I want to highlight certain points in the graph.
Best answer by IRstuff
Just double click on the graph, select Traces, select Points as the "Type"
TTFN
Something like the attached?
Mike
So i put my points in a X and Y vector and plot those.
Let me try
You could post a worksheet showing an example of what you want.
Mike
I simply put the x and y coordinates of the point on the respective axes, select a symbol, give the symbol enough weight to be seen and change the line type to points. See one of the plots in the attached file
To ensure the maximum audience post your worksheets in M11 format.
Mike
