How do I stop Objects from migrating within Mathcad doc?
  • November 20, 2013
  • 1149 views
I am new to working with Mathcad (version 14). Updating a file created by retired co-worker (so no help there), I discovered that a bunch of tables (imbedded XL spreadsheets) have moved from there original positions in the document. Besides the fact that they are overlapping test and equations I checked a PDF of the original document. I did my updates and moved the tables back into position, I saved the file and opened and closed it a various times with no change so I figured it was a one time problem or a corrupted file. I then emailed the new file to my boss and he asks me why I had tables scattered through the text.
What am I doing or not doing that I need to change to anchor these objects?
Is your boss using the very same version of Mathcad?
I know of similar effects with text boxes when zoom factors different of 100% were used in creating the sheet.
I think that some positioning depends on the screen resolution and on the DPI setting of the screen font (std. 96).
If thats the problem (not sure about that) I guess there is not much you can do against it other than using the very same version and settings as your boss.
