How do you get mathcad open text file with notepad?
  • August 26, 2011
  • 9 replies
  • 5088 views
I saved some text using the WRITEPRN function.
I would like to open this file with notepad.
Tried button with script using open or shell command but it did not work any ideas?
Best answer by MikeArmstrong
Did you find the worksheet I posted any use?
Mike
This button fires up Notepad from with Mathcad.
Mike
I've just re-read your question
Why would you want to open a text file from within Mathcad?
Mike
The file contains some test instructions to be saved in a database, Just trying to create an easy shortcut to the file for the users.
Mike
